3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 64 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#1401156 03/13/2021 12:32 AM
I'm sure this topic must have been covered a million times, but I will keep it short... Can I use Rotella 20W-50 (detergent) engine oil on a 216 engine with no issues or leaks? I live in a hot climate and wonder if the 20W-50 will make it a little easier on the engine... I'm using non-detergent Valvoline 30W at the moment.
Philippe Jeanneau
I use 15W-40 in every engine at my place- - - -cars, trucks, tractors, lawn mowers, generators, and even a Harley EVO engine. No problems yet, and I buy it in 5 gallon pails from the local farm store at a considerable discount over quart bottles.
So, that would mean that the 20W-50 would be too heavy for the 216 engine?
Philippe Jeanneau
Not necessarily- - - - -it would depend on how much clearance the connecting rods have. Multi-weight oils actually stay at the physical thickness of the minimum weight- - - -20W-50 flows like a 20 weight when cold (0 degrees F.), and lubricates like a 50 weight when hot. The oil doesn't "thicken"- - - -it just has better lube qualities when it's hot than a straight weight oil. Any multi-weight oil including 20-50 will be "thinner" than the 30 weight you're using now. Most 20W-50 "racing" oils are just outrageously expensive, compared to Diesel-rated 15-40. The Diesel oil also has additives that are kinder to your flat-tappet camshaft than the racing oil.
Thank you very much for the insight... I will try the 15W-40 diesel oil...
Philippe Jeanneau
