| | | Forums66 Topics128,050 Posts1,055,754 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | I'm sure this topic must have been covered a million times, but I will keep it short... Can I use Rotella 20W-50 (detergent) engine oil on a 216 engine with no issues or leaks? I live in a hot climate and wonder if the 20W-50 will make it a little easier on the engine... I'm using non-detergent Valvoline 30W at the moment.
Philippe Jeanneau
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I use 15W-40 in every engine at my place- - - -cars, trucks, tractors, lawn mowers, generators, and even a Harley EVO engine. No problems yet, and I buy it in 5 gallon pails from the local farm store at a considerable discount over quart bottles. Jerry
| | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | So, that would mean that the 20W-50 would be too heavy for the 216 engine?
Philippe Jeanneau
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Not necessarily- - - - -it would depend on how much clearance the connecting rods have. Multi-weight oils actually stay at the physical thickness of the minimum weight- - - -20W-50 flows like a 20 weight when cold (0 degrees F.), and lubricates like a 50 weight when hot. The oil doesn't "thicken"- - - -it just has better lube qualities when it's hot than a straight weight oil. Any multi-weight oil including 20-50 will be "thinner" than the 30 weight you're using now. Most 20W-50 "racing" oils are just outrageously expensive, compared to Diesel-rated 15-40. The Diesel oil also has additives that are kinder to your flat-tappet camshaft than the racing oil. Jerry
| | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | Thank you very much for the insight... I will try the 15W-40 diesel oil...
Philippe Jeanneau
