0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#140059 02/19/2005 9:10 PM
Junior Member
Junior Member
I just found a 46 chevy truck"doodle bug"would those wheels be the same as on my 51?whole truck only 150$
car nut for life!
#140060 02/20/2005 8:11 PM
Quote
What is a doodle bug?
#140061 02/21/2005 4:43 AM
A "Doodle Bug" is a homemade utility/farm tractor. Take the front half of a Model A or 32 Chevy or what ever is sitting around, strip everything off leaving just the dash/cowl, hood and radiator shell. Then weld a big truck axle (single or dual wheel) directly to the shortened frame (you end up with about a 60-70" wheel base)and direct connect it to the trans. Then bolt some sort of a seat and fuel tank and there you go!
I think there were plans available in Popular Machanics on how to do it back in the 40's .
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#140062 02/21/2005 5:57 AM
If the wheels have ten holes they might fit. Given what this thing is, I would not be surprised if the axle isn't a '46.
I don't know how to be sure. If the axle has any numbers on it someone may be able to look up the numbers to correctly identify the axle.
#140063 02/22/2005 12:40 AM
Junior Member
Junior Member
I just realized I left out some info in my Q:the 46 being a 2ton,would it have the 10 bolt 20" rims?the seller is somewhat hard to get a clear answer out of,and the "truck" is like 7-8hrs away,so I want to be sure that it would have the right boltpattern before I buy it.
car nut for life!
