0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | I just found a 46 chevy truck"doodle bug"would those wheels be the same as on my 51?whole truck only 150$
car nut for life!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by swedester: I just found a 46 chevy truck"doodle bug"would those wheels be the same as on my 51?whole truck only 150$ What is a doodle bug?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | A "Doodle Bug" is a homemade utility/farm tractor. Take the front half of a Model A or 32 Chevy or what ever is sitting around, strip everything off leaving just the dash/cowl, hood and radiator shell. Then weld a big truck axle (single or dual wheel) directly to the shortened frame (you end up with about a 60-70" wheel base)and direct connect it to the trans. Then bolt some sort of a seat and fuel tank and there you go! I think there were plans available in Popular Machanics on how to do it back in the 40's . Mike B  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If the wheels have ten holes they might fit. Given what this thing is, I would not be surprised if the axle isn't a '46.
I don't know how to be sure. If the axle has any numbers on it someone may be able to look up the numbers to correctly identify the axle.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | I just realized I left out some info in my Q:the 46 being a 2ton,would it have the 10 bolt 20" rims?the seller is somewhat hard to get a clear answer out of,and the "truck" is like 7-8hrs away,so I want to be sure that it would have the right boltpattern before I buy it.
car nut for life!
