1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 43 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 43 | I bought a condition unknown 235 at a flea market. A visual tells me it was probably rebuilt at one time and the top end was pretty clean. i have mounted it on a temporary stand and have soaked cylinders with marvel mystery oil. I have also lubricated valve stems and tappets. I have been able to rotate the crankshaft using a prybar against the dowells on the rear crankshaft flange. However, I continually hit a sticky spot at the same spot on the 360 degree revolution.I have continued to soak it and rotate the crank through the sticky spot. I have thought of bolting on a flywheel, bellhousing and starter that I have and seeing if it will start . The sticky spot worries me but I don't want to invest money in new parts or a ring job . I was hoping for a driver motor that had a few miles left on it My gut feeling tells me to invest in at least a gasket set. Any advice on working out the sticky spot will be appreciated. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Read and re-read the Tech Tip here on Stovebolt about resurrecting a long dormant engine. Then proceed at your own risk.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | GEO 55 The local body shop got a car stuck so tight they took out the tranny and clutch bolted on an 8 ft. lever and finally broke it loose. A few days later I was in there ,he said try it...ran like a sewing machine ! Lube-up your valve stems and try it !!! Might have a mud dobber nest at that tight place ! | | |
