3 members (kades51, 66flea, 1 invisible), 113 guests, and 2 robots.
Topics128,134
Posts1,056,736
Members48,454
#1400330 03/07/2021 4:20 AM
Hey guys. I am new member to the forum, and have found good info here for projects I've done in the past. I'm hoping someone can help me identify this new to me truck. I drive a ten wheeler Pete for a living and last week on a job I noticed this old Chevrolet dump. The guy was going to scrap it as it had been left on the property since 1995. I trailered it home. I like it. I can't find out just what year and model it is. Has a big 6. Fired up after working on it today.
Sounded like the crank was broke. Shut it down. Realized that the crank pulley was loose. Pulled it off and pulled the woodruff key and fired it up again. Ran like a champ with good oil pressure. Maybe the guy who owned it back in 1995 (last reg) figured the crank had broke and walked away. The rats had a fine time in there past few years. I'm going to post a pic of the truck and also the id tag. Maybe one of you guys can tell what year and what GVWR this might be. I'd sure appreciate it. Thanks.
Hope the pics load. Serial # OC6330103426
rlv
That looks like 1960 two wheel drive 2 ton cab and chassis built in Oakland 3425th off the line to me.
0= 1960
C= 2wd conventional cab
6= 2 ton
3= ? perhaps wheelbase
3= Cab and chassis
O= Oakland
The rest is the build number starting at 100001.
Steve
Steve
1946 1/2 ton
Nice save. thumbs_up
Hey, thanks so much for that info. I really appreciate it. I worked on it today, and put in a new woodruff key. The crankshaft keyway is still intact. A friend told me the harmonic balancer/pulley has a sleeve on it. A jiffy sleeve I think? The pulley still has some play so I must make a repair.
I believe this was a friction fit originally. Do you guys think I should drill and tap the crankshaft? Should I look for a good used pulley assembly? This crank was never tapped for a bolt. My old Pontiacs (1957/1952) have a bolt to secure the pulley.
Would appreciate input on this. Looks like the way to go. I will be watching the site for the best advice. A lot of knowledge here. Thanks.
rlv
0= 1960
6= 2 ton
3= Cab and chassis
O= Oakland
Steve
The "3" in question is in fact the wheelbase...157".
The other thing I would add is that by 1960 calling trucks 1-1/2 or 2-ton rated was being phased out as GVW ratings for any given series could differ by thousands of pounds based on what tires and suspension got installed, so in this case the "6" would be the Series identifier (60 Series).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Former Workshop Owner
Hello Rob, your dump truck is awesome. Lot's of potential. thumbs_up
Welcome
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Forgot to say Welcome to the Bolt wave
Also forgot to say your GVW could be between 15,000 and 22,000 pounds.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Is that a 1960 hood? The grille looks like it, but the hood looks newer. Maybe transplanted at some point?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
It has, as you may know, a 62 ~ 66 hood.
Can't beat the torsion bar ride! (60 ~ 62)
What part of California you in?
BC
1960 C60 pasture art
AD Addict & Tinkerer
Nice find! Good luck with your new project and welcome to the “Bolt”! shake
Phil
Project Journals
Stovebolt Gallery Forum
Yes, the hood. I noticed it looks different than other 1960 hoods I've seen. It was up in the mountains behind Watsonville Ca. hidden by tall weeds. I'm in Santa Cruz. Last reg was 1995. The guy I am hauling baserock for bought the property in 2017, and this was on the property abandoned. Well, except for the rats. A real rat motel. A few scurried as I cleaned it out. I'm glad to have saved it from the crusher.
The wheelbase # is right on. I measured it today. 157". The crankshaft snout SEEMS undamaged using my calipers with a good keyway. The balancer took the damage. A buddy has the og inline 6 from his Chevy, and gave me the part. I held it up to the crank and it will be a press fit on. Good. Going to drill and tap and bolt on at his suggestion. He made a tool so as to center the bit.
Pulled a rim and rotten tire off it today. Widowmakers. Will go to truck tire shop tomorrow to see what I can find for replacements. Rims in poor shape. 10 lug 8.25x20. To me this is great fun. Great forum too. Thanks.
rlv
