6 members (1955 1 Series, Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl), 110 guests, and 3 robots.
Topics128,087
Posts1,056,119
Members48,435
1950 Chevy 3100 216 3 Speed.
Does anyone have experience removing the paint off the vehicle ID data plate. Also, what does the unpainted data plate look like for a 1950 Chevy 3100? Last night I tried brake fluid, and not even a ripple. I have heard about using the oven cleaner OFF with the yellow cap. This is a one time thing so if it is possible I would like to get it correct if I can recover the original detail of the data plate.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
I had some really old (well cured) overspray on mine and got it off with some xylene on a shop towel. Don’t have a picture available right now. It it’s polished aluminum border with black interior.
Very well said ,that is going to be a real pain to get the paint off. You might try a heat gun ,to get some blisters and try to peel
!956 Gmc Napco 4x4 Factory line built .
I will try to remember tomorrow, to take a pic of my truck's plate.
Craig
Curmudgeon
Curmudgeon
Here's a 1950 1/2 ton with the original screws.
During the summer I worked in a body shop when I was a kid.
I was shown how to use lacquer thinner to remove any overspray.
A little bit on a rag and rub to take the paint off.
The thinner evaporates quickly so you continue rubbing, as needed, till the paint is gone.
Old, dry, hard paint takes longer and a lot more time rubbing.
You may have to take very fine sandpaper and gently/evenly thin-out the topcoat a little.
Then follow with the thinner and more rubbing.
Basically you are taking the paint off in even layers as the color changes.
I would stop when you begin to see the text.
If you continue you risk removing the original black paint.
A lot of these old trucks have overspray and crud (I call it patina).
You only need to show enough, that there is an original vin tag underneath the paint.
Do not use shop/commercial paint stripper.
It will bubble up all the layers of paint and attack the aluminum plate.
bouymaker, Great advice that I can second. Question, the data plate you show has Hutch screws, I though rivets were the factory method of attachment. Have you seen many with screws?
RonR
RonR
1970 340 Duster
1964 CJ5
These special screws were in place until the ‘51 Model year when they went to rivets.
https://www.flickr.com/photos/advance-design_parts_co/9110621847/in/album-72157631868452754/
Here is a factory filmstrip shot from 1948 showing them.
https://www.flickr.com/photos/advance-design_parts_co/17057160050/in/album-72157651722976780/
Curmudgeon
Curmudgeon
Here is an original 49 and 51 (attached).
This information is provided to help determine if a truck has the original VIN tag.
Today it is illegal to remove a VIN tag and/or alter, move, swap or modify one.
The clutch head screw is a special design.
The rivet is not hollow. It is slit(?) to expand out on the backside.
I attached a picture of a repop with modern rivets.
This was on a $50K "restored??" 1954 1/2 ton.
If it was my truck, I would have taken the extra step to make it legit with my state DMV (probably re-stamping).
OP’s question has been answered, so closing the thread.
