9 members (Jon G, JW51, kades51, baldeagle, 68ironhead, Stovebolt48, GMCJammer51, dt235sd, 1 invisible),
55
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | As many of you know I'm laid up for a while. I have an old friend that really knows his way around old cars and trucks. He can't get my 54-3100 235 running smooth. He noticed that the rotor button is loose on the shaft. When I was in the parts business a customer came in with the same problem, we found out that we had sold him an International 6 cyl. button, which fits a Chevy but is a little loose. I just spoke with the Jim Carter folks and John said this is a fact. I have a NOS original GM condenser, but I would like to get the capacitor that one of the Stovebolter's makes. Who is it? Doc.
| | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | A piece of shim stock (or a slice cut from a Coke can) will probably serve to tighten up that rotor if you don't want to replace it. Jerry
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | You could probably use a piece of paper of thin card stock too.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Mar 2014 Posts: 4,474 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,474 | Hi Doc, I'm the condenser / capacitor guy. However I will be out of town for about 10 more days. Please contact me then. Email is a good way to connect. Scads of folks use it to communicate with me all the time. My address is [email protected]
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Thanks Jerry, I will tell my friend to do that. Ed
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think I would get the correct rotor. That thing rides close to the terms. in the cap. It only turns half as fast as the engine but at high rpm it could wobble enough to contact one & thats were you will be. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | I think I would get the correct rotor. That thing rides close to the terms. in the cap. It only turns half as fast as the engine but at high rpm it could wobble enough to contact one & thats were you will be. George Good advice. Rotors are cheap.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | As a temporary fix only, shimming the gap between the rotor and the shaft will move the tip AWAY from the cap contacts a few thousandths of an inch, and also stabilize the wobble. Shade tree fixes are usually more effective than some folks think. Jerry
