6 members (66flea, moparguy, ronsway, TUTS 59, 1955 1 Series, 1 invisible), 347 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
I bought a 1952 1-1/2 ton Chevy recently. It has a 235 with an oil bath air filter and Rochester carburetor with a manual choke.
I know the 1/2 ton had a 216 in 1952. What did the 1-1/2 ton have? I thought some of the heavier trucks had low pressure 235s instead. I'm trying to find out if my engine is original.
Thanks for any help on this issue.
Rob Mathis
48 Half Ton with 235 & SM420
I believe you are right that the 235 was used in big trucks before it was used elsewhere. But since this motor is in a 50+ year old truck, you should check the casting and serial numbers to be sure you know what you have.
My '52 has a stock looking motor in it, but my '51 1-1/2 ton has a later motor in it. I've not yet checked numbers to see if they are what I think...
It might be the "boat anchor" low-pressure 235. If you're lucky, it has a later 235 or a 261 in it. There is an article on the big trucks around here: http://www.stovebolt.com/features/bigtrucks/index.htm
1954 GMC De Luxe COE
the 235 was the original engine that year. i believe by 52 the better engine was used. 48 mph.
Thanks for your help. My 235 (1952 1-1/2 ton) does not have the two acorn nuts but rather four bolts that secure the valve cover around the outside flange. So I guess this means that my 235 is for sure high pressure and not original to the truck. (this truck ran until 10 years ago.)
How can I find the year knowing the block number off the engine adjacent to the distributor?
Rob Mathis
go here web page to check the numbers
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
my 46 has the orgnl 235 wich is realy a board and stroked 216
and one of my 50 parts trucks has a difrent 235 it looks like my old one but evrything is bigger and wont enterchange with the old low-pressure 235s or the newer hi pressure 235s
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
