1 members (55shaker),
104
Mod | | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,432 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,432 | Looks to me like your 261 stroker has transformed itself into a boat anchor. Not sure if it can be sleeved. Hopefully Jerry will offer his opinion.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2008 Posts: 902 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 902 | bigmacdaddy, it don't look good for the home team.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | bigmacdaddy Unless there is worse damage below,that can easily be repaired with a sleeve,if its an overbore may take a 1/8th sleeve. They used to take the hood off and do it right in the truck,saved a lot of disassembly ! | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | If the crack does not extend to within 1/2" of the top or bottom of the cylinder, installing a sleeve will not be a problem. Use a 1/8" wall repair sleeve to add more rigidity to the repair than a 3/32" thick one will provide. Leave a step at the bottom of the cylinder approximately 1/4" tall for the sleeve to bottom out against and trim the top flush with the head gasket sealing surface. I have sleeved cylinders on small block Chevy race engines with connecting rod sized holes in them without a problem, and run a full season of 1/4 mile dirt track competition with them. That's a tougher environment than your engine is ever likely to encounter. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Any idea what caused this problem?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Pre68 Dave That is a factor to be sure of what happened so it wont happen again,if something pounds the piston ring groove closed on the ring it will split the cylinder. Usually up higher than that. That one has crosshatch but may still have taper. | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | What oversize were the cylinders bored when the engine was machined? The damage is approximately 45 degrees away from the thrust face of the piston skirt, so I'm guessing there was a casting flaw from the back side that did not show up until the cylinders were bored. A small coolant leak from a pinhole or a small crack could partially fill the cylinder with coolant, and the next startup could produce the displacement of the cylinder wall that shows up in the picture due to hydraulic locking of the cylinder. Jerry
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | It was so long ago that I had the motor built. I vaguely remember having to bore larger, due to cylinder wall pitting. I think I originally had .050 over pistons, and had to go to .080. I also can't remember if we sleeved, or just talked about it as an option. Either way, this sucks. Still trying to get ahold of builder, and trying to figure out what we did. This is what I get for dragging my feet. | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | bigmacdaddy, great project but bad luck for sure. A couple minutes with Search produced a post of yours from '07 that I've copied below. In it you provide details on your build, mentioning the block was bored .050 over. You do mention .080 over if you had used .030 over Cadillac pistons, an option you didn't use if I read your post correctly. Best of Luck RonR Re: balancing #7307012/02/07 10:56 PM Joined: May 2004 Posts: 913 Seattle B bigmacdaddy Online OP Shop Shark As far as I know, the original idea came from Tom Langdon of Stovebolt Engine Co. He wrote an article about it a year or so ago for 12 Port News which is the newsletter that accompanies another online club -Inliners International. The basics are that it is a 261 block. Mine has been bored .050 over. The pistons are standard size from an 84 cadillac 365 V-8. One could also use .030 over caddy pistons and bore the block .080 over. The crank is offset ground to work with the 292 rods which will increase the stroke. Exactly how much I would have to look up. Beyond that, I will be using a mild cam with hydraulic lifters, a 2X1 Edelbrock intake and 2 Rochester single bbls. The 848 head from a 235 will be decked and milled slightly with 261 springs and powerglide intake valves with a 4 angle valve job. And of course, a split manifold with duals and HEI. My transmission is an SM420 mated with a Gear Vendors Overdrive. It is basically a 7 speed. I still have my granny gear and I can overdrive 4th. This gives me the equivilant of a 3:08 rear on the freeway without having to sacrifice low end torque - it is still there when I need it. My Webshot Photos [community.webshots.com] 62 Fleetside 4spd 235 w/O.D. posi 3:90 90 Subaru Legacy Wagon AWD 2.2 5sp 13 Ram Tradesman C/V http://www.stovebolt.com/gallery/madia_matt_1962.html
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Hey Moparguy, Thanks! I was doing the same backtracking as you posted! I also discovered that I had the engine built in the summer of '13, but didn't post any details after all was said and done. I do believe I had to get the .030 over caddy pistons after discovering the pitts, meaning the block must have been re-bored at .080 over.
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | I'm building a similar stroker engine, but I've figured out a way to do it with regular 261 pistons- - - -not the scarce and pricey Cadillac ones. There's also a NASCAR-style H beam rod for a Nissan engine that can be adapted to take the stroke out to 4 5/16 ", also with stock 261 pistons. That one requires some whittling on the crankshaft counterweights and piston skirts to keep those parts from getting into contact with each other. With a .040 overbore that one comes out to 292 cubic inches. Jerry
