3 members (Otto Skorzeny, Tronman, 1 invisible), 124 guests, and 3 robots.
Topics128,142
Posts1,056,476
Members48,441
#1398785 02/25/2021 4:00 PM
Is there a trick to installing the manifolds without a helper? Everytime I think I have it something moves or the intake centering ring will pop out of place. I even entertained the idea of spot welding them in place which I quickly decided against, made me smile though.
You might want to mention make, year, model truck/engine/manifold?
The Manifold should hang on the two studs located at both ends.
As for the rings, gently expand them so there is a little spring pressure holding them into the manifold.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If it is a 216/235/261 manifold-assembly, I'll offer other suggestions.
This forum now states/supports 1916-1987 trucks (and, just about any engine).
One possible problem with 216/235/261 manifolds are the alignment rings being too "wide" due to the mating surfaces on the head and/or manifold-assembly having been "planed" for a flat-fit/match.
Try removing the alignment studs on both ends of the head and replacing them with 3/8" bolts a little over an inch long with the heads cut off. Once the manifold is installed, you can replace them with the short dowels if you cut a screwdriver slot in the short ones.
Crusing in the Passing Lane
Make sure to just snug up the inter manifold bolts, tighten up the bolts to the head before tightening the inter manifold bolts, last.
Ed
Thanks for the ideas guys. I was to the point where I was going to get my mini sledge and start swinging!!! All my friends have died so I'm having to do everything alone. I need to grow a few more arms. Lol
You could try making new friends, also! The problem with that ides is finding anyone younger than 40 who wants to do manual labor, or hang out with an old geezer. All their "friends" seen to be on the social media platform this forum doesn't like! Good move, John- - - -I agree completely!
