2 members (2-Ton, NJC),
68
Mod | | | Forums66 Topics128,263 Posts1,058,134 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 4 Moderated | | Moderated Joined: Feb 2021 Posts: 4 | I have a 1986 GMC that needs a new dash pad. Has anyone replaced their dash pad recently? If so, where did you buy the replacement pad that you used and how satisfied are you with the results? Also, what is the level of difficulty with doing this with the windshield in place? Thanks! | | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | LMC truck or any of the reputable vendors of this era truck parts will have A decent pad. If you have one of the common interior colors you can order the pad colored. Otherwise your going to have to paint it.
The glass does not need to come out. You remove the gauge cover by removing the screws surrounding it And the lower cover around the steering column. Then the screws at the bottom of the cover along the dash paint line Lift up front of cover and pull toward you and that will release the clips at the bottom of the glass.
I'm sure there's probably a U-Tube video out there.
Good Luck, Tom | | | | | Joined: Feb 2021 Posts: 4 Moderated | | Moderated Joined: Feb 2021 Posts: 4 | Tom, thanks for the info. Have you used one of the LMC dash pads? So installing the replacement would just be a matter of getting the clips lined up properly and then popping the pad into place? I couldn't tell exactly how it is retained by looking at it so your description is a big help. | | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | Yes I have but many years ago. I'm sure there still good.
Also they make slip over covers that are not bad. Sometimes that works well.
Forgot to mention there is a screw on the side at Each end of the pad.
You start the clips in place then reinstall all the screws. Tom | | | | | Joined: Sep 2020 Posts: 9 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 9 | dash pads are very easy to replace and do not require removing the windshield. I would suggest USA 1 Industries, https://www.usa1industries.com/ they have great products.
1956 Chevy 3600 Napco 1974 Chevy K20
| | | | | Joined: Jul 2021 Posts: 13 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 13 | I have a 1986 GMC that needs a new dash pad. Has anyone replaced their dash pad recently? If so, where did you buy the replacement pad that you used and how satisfied are you with the results? Also, what is the level of difficulty with doing this with the windshield in place? Thanks! How did it go? Have you successfully replace the dash pad on your car? | | |
