0 members (), 188 guests, and 3 robots.
Topics128,089
Posts1,056,441
Members48,443
I have seen similar posts on getting the door gap correct but try as I might I am know where’s near solving the problem I have a 1/4 to 3/8 gap at the right front bottom of window and cowl,panel. I have tried enlarging the top hinge slots by 1/2 inc. Tried bending both top and bottom hinges but still no luck. These are
Donor doors as the truck came with vented window 1951 doors and I wanted the correct 1950 doors. The 1951 doors fit fine. i am beginning to wonder if it is the door it self. I do not have the strikers in at all so I am sure I can lift the left side so the body line is correct. It is the unusual gap I have mentioned on the right side that is driving me to frustration. Any thoughts would be appreciated.
Rick
Some responses on your other post here
Locking this thread as duplicates aren't allowed (pick the best place and post there). You might want to edit your other post to include some of the additional information above if you think it's pertinent. If you do that, I'll remove this thread.
