6 members (NJC, 55shaker, Joe H, DannyW, 2-Ton, Gdads51), 66 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
Bolters,
I have a 1958 Apache 31 and am looking to find out how I can obtain the Factory Build Sheet / Line Set Ticket for my particular truck. Does anyone have any knowledge of what I am asking?
John in Raleigh, NC
Leo Offline
Moderator
Moderator
Here in Canada we have Vintage Vehicle Services. They go back to 1945, GM vehicles only, that were assembled here. Not sure what is available in the US.
Originally Posted by raleigh58
Bolters,
John in Raleigh, NC
If you think you have an original seat that's never been re-upholstered look on the underside, I know the trucks like mine (68 C10) you could find the build sheet in between the springs and the seat cushioning/stuffing. Look at both bottom seat and the back of the seat.
Ask a question if you need a answer!
Resting up on Mon-Fri from Sat and Sun.
Thanks MJ. Nothing there. We upholstered the seat when we did the restoration. I took the seat out myself and never saw any paperwork attached to the seat bottom or back, but thanks for the suggestion.
I've never seen a "Factory Build Sheet" on any TF truck. The only info GM shares for our trucks is from the GM Heritage Center.
https://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
MJ Gor'don On my 72 one ton was a sticker on the glove box door that showed several thing what is that ?? Also in the glove box was a little bruchure that showed 3 different posi-tracs that could be in the truck. theone in there was tough but would bind at times and kind of force you toward the ditch...then release and be fine. Found out it needed whale oil,it really worked,and I never did see it !!
thanks Mike B!
On the inside Glove Box is your SPID or Service Parts Identification Lable. Go to this website called "outintheshop.com" for whats on the SPID. I had a new SPID made up for me.
MJ who made up a new one for you??
1951/54
Basketcase
You can buy blank SPID sheets from classic parts. I'm going to try and match up the font and reproduce the options on my 67.
Another quality post.
Real Trucks Rattle
