2 members (MNSmith, Otto Skorzeny), 92 guests, and 2 robots.
Topics128,130
Posts1,056,717
Members48,454
Jim Carter Truck Parts has as of January 10, 2021 a new assembly for the round recirculator GM heater. I have one on order for my 1954 3600 to replace my original leaking one. Item number MEH248. Price is $225.00
I installed that heater core in my '51 last summer. Been working great all winter, no issues at all. Pretty much an exact replica. I did break the motor down and lubed the bearing/bushings. Highly recommend this little bit of PM.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
moparguy Did you just lube with oil or use something special,at a motor factory Ionce serviced they had their oilite bronze bushings in a special lube, a lot of those motors are still running after 30 years.
Nothing too special, I had some 0w40 synthetic in a open container and used a very small amount of that.
RonR
1970 340 Duster
1964 CJ5
That "Donut" heater core from Jim Carter looks great. I paid over $300 to have my old one rebuilt and I do not even run my cooling system pressurized (0 psig). I remember obtaining the 12 VDC fan motor from Grainger which was a perfect fit. It works well and does not steam my windsheild.
Good find dad8084!
Crusing in the Passing Lane
moparguy, have to be careful about ‘open container’ with the police around.
Ed
Ed
True! I think even Montana has joined the rest of the lower 48 in that regard at least as related to vehicles and open containers. Hopefully still OK in the sanctity of one's shop. If not I'll just have to make sure Martin opens one smile
RonR
RonR
1970 340 Duster
1964 CJ5
Bolters- Have heard a lot about heater troubles this winter/ If you put in air conditioning (old air) doesn't it give you a new modern heater right along with your cooling system !!
The Vintage Air System I installed in my '56 3100 does have integrated heating as well as cooling...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderator, Electrical Bay
J Online: Content
Yes, with variable fan/temp control and dehumidified defrost air on the Old Air unit.
~ Jon
I originally built my truck to look original so i kept the round recirculating heater because the heater box and gmc tag was mint with factory paint. I did put the new upgraded heater core in it from brassworks and it works great especially running at 199 degrees or hotter. I ended up wanting AC later and I figured I already invested in that nice heatercore so i was keeping it and that vintage air underdash setup looked period correct for the 50’s and into the 60’s so I used that and because it fit so well. Im very VERY happy with my setup. It blows 42 degrees all summer and it was a fairly easy setup and CHEAP for me to build.
Your under the dash unit looks nice!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Thank you! Check out the pics in the new gallery. You can get better views of the interior and how well it fits.
Jon G Thanks for the reply,hope to put Old Air in my 51 6400 I think that big radiator might be pretty successful for that. Truck never offers to overheat in HOT weather now. 235 run of the mill insert brg. upgrade.
