9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | Finished the 6.0 LS swap into my 1958 6100, you can see it running here: 1958 Chevy Truck LS Swap RunningI need to re-do the brakes now, it stopped when I got it but now the master cylinder was dry and when filling it the fluid stays in the cylinder and doesn’t drain to the lines. Does anyone have the part numbers for the 2 ton truck brakes? I also have single piece budd wheels that I will put on, will 10.00 x 22.5 tires fit or do I need 9.00 x 22.5?
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | rear brake hose (58) UP4000 BH4000 front brake hose (58) UP 25664 BH25664 front brake hose (58) (no NAPA number for this one) , BH36548 rear wheel cylinder kit 1 1/2 bore, ring type UP 147 WK147 master cylinder kit 1 1/4" UP 33 MK33 front wheel cylinder kit 7/8" UP 129 WK129
this is what I found for my 58 Viking 6400. first part # for each is Napa, the 2nd part # for each is the Raybestos part # | | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | Thanks, I bought all of those parts today. Now to find 9r22.5 tires | | | | | Joined: Jul 2020 Posts: 112 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 112 | Thanks, I bought all of those parts today. Now to find 9r22.5 tires Theres another gentleman here that went with 10r22.5 wheels & tires. Little bit taller too for some extra overdrive. I am hoping 11r22.5s fit on these trucks. If love the 42" tire for even more overdrive goodluck!
THE BLACK VIKING 1958 Viking 60 ~ my new toy hauler My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60 Keep 'em rollin fellas!
| | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | I got original Budd wheels that are skinny, would 10r22.5 tires rub on the back? I should be good with the overdrive on the 4L80E transmission but more tire wouldn't hurt. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I also have single piece budd wheels that I will put on, will 10.00 x 22.5 tires fit or do I need 9.00 x 22.5? The max size tires for the 6000 Series TF trucks is 10-22.5 (9.00-20"). If you try to run anything bigger the rear duals might touch each other and any bigger on the front and they will hit the fender on hard turns. Also, your engine start link didn't work for me  Mike B  | | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | Thanks, that's a big help, found a set for a good price, I fixed the link in the original post. You can also see the truck here 1958 Chevy Truck LS Swap Running
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Looks like you have tons of power now! Racking the miles up 50' at a time...love it! Mike B  | | |
