2 members ('37 barn find, Jeff Ogden), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
Finished the 6.0 LS swap into my 1958 6100, you can see it running here:
1958 Chevy Truck LS Swap Running
I need to re-do the brakes now, it stopped when I got it but now the master cylinder was dry and when filling it the fluid stays in the cylinder and doesn’t drain to the lines.
Does anyone have the part numbers for the 2 ton truck brakes? I also have single piece budd wheels that I will put on, will 10.00 x 22.5 tires fit or do I need 9.00 x 22.5?
Big Bolt Forum Moderator
rear brake hose (58) UP4000 BH4000
front brake hose (58) UP 25664 BH25664
front brake hose (58) (no NAPA number for this one) , BH36548
rear wheel cylinder kit 1 1/2 bore, ring type UP 147 WK147
master cylinder kit 1 1/4" UP 33 MK33
front wheel cylinder kit 7/8" UP 129 WK129
this is what I found for my 58 Viking 6400. first part # for each is Napa, the 2nd part # for each is the Raybestos part #
Mike
Thanks, I bought all of those parts today. Now to find 9r22.5 tires
Theres another gentleman here that went with 10r22.5 wheels & tires. Little bit taller too for some extra overdrive. I am hoping 11r22.5s fit on these trucks. If love the 42" tire for even more overdrive goodluck!
THE BLACK VIKING
1958 Viking 60 ~ my new toy hauler
My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60
Keep 'em rollin fellas!
I got original Budd wheels that are skinny, would 10r22.5 tires rub on the back? I should be good with the overdrive on the 4L80E transmission but more tire wouldn't hurt.
The max size tires for the 6000 Series TF trucks is 10-22.5 (9.00-20"). If you try to run anything bigger the rear duals might touch each other and any bigger on the front and they will hit the fender on hard turns.
Also, your engine start link didn't work for me frown
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, that's a big help, found a set for a good price, I fixed the link in the original post. You can also see the truck here 1958 Chevy Truck LS Swap Running
Looks like you have tons of power now!
Racking the miles up 50' at a time...love it!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
