1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
Apprentice
Apprentice
Running a Chevy 350 and looking for race type long tube headers that will fit inbetween frame rails on a '64 c10 with no cutting. I have no clutch linkage to worry about and have Vortech heads. (Spark plug clearance?) Thanks!
'64 C-10 Longbed Fleetside Custom with large window. BRE 383 stroker with Turbo 350.
I know I put a set of Hooker headers on a 63 I built back in about '89 that seemed to fit good if I remember correctly. It had a small block "not very stock" 400 in it. It seems like I just ordered what the catalog said would fit. Those are fairly common headers since those pickups came with small blocks in them. Do Vortech heads have a different exhaust port configuration than the earlier small block heads?
Jeff
Apprentice
Apprentice
Quote
Jeff
I've been eyeballing hookers at Jegs. They do list them for the '64, but my experience is that the manufacturer doesn't always give out info such as if the headers won't clear the frame rails. I'll give them a call. Thanks!
Hooker Comp series on mine, fit well-I had to grind maybe 1/8" or so off the driver's frame rail in one spot-the header cleared but I wanted some extra wiggle room.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Apprentice
Apprentice
Quote
Sounds great and thank you!!!
