2 members (latroca52, 1 invisible),
131
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Can anyone confirm that the metering rod gauge for the Carter (W-1) 420-S is a Carter T109-26? Thank you.
Philippe Jeanneau
| | | | | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | I can confirm that it is NOT!
The gauge used for the 420s is T109-25.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Hello Jon,
Thank you for the correction... Interesting fact that it is the same tool used for the Carter (W1) 391-S... The T109-26 is used on the Carter WO carburetors, it seems...
Philippe Jeanneau
| | | | | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | Generally, only one or sometimes a couple of metering rod gauges, will be used on virtually all Carter carburetors of a given type.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Thank you for the education here, after some consideration, it would make sense that the W1 carburetors would use the same metering rod tool...
Philippe Jeanneau
| | | | | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | The T109-26 is used on some (not all) of the W-0 carbs.
We sold out of these (about 75 units) to the Jeep folks.
Someone has reproduced them somewhere, even to the Carter logo on the tool, and are being offered at ridiculously low prices.. Have not seen any of the repros, so cannot comment on the quality of this unit, but a lot of repro stuff like this is not overly great quality. This post information only, again, we are sold out of this tool.
