| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | I asked this a little while ago but.. I am slow of mind so Here I go again. I have a 54 3100. I am in process of installing a TCI Mustang 2. Although I understand about shortening the collumn( I am going to use the original) Is there a step by step guide/ how to etc. I know I need to get u joints and some other parts but I have not seen a true 1 2 3 A B C's of how it is done i/e welding & so forth. :confused: My truck is patiently waiting for me and this is my free week to tackle. Thank You in advance. Jack
Try prayer as the first response rather than a last resort ...
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Link There is some controversy regarding the altering of stock steering components. If you're not up for the job consider getting another column suitable for your needs. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Good advice from Ghostrider. Most everything you can do to one of these old trucks is a very forgiving situation. But if it concerns how it stops or how it steers, it's worth it in the long run to bite the bullet and buy something from a reputable source and the rectal irritation you'll avoid is worth it in the long run. After all, it's only money...right? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Tramp is almost right, "it's only money and your A#@." Besides, an aftermarket collumn will come with a tilt.
~Jim
