2 members (JW51, Phak1), 141 guests, and 3 robots.
Topics128,269
Posts1,058,402
Members48,485
#139568 10/05/2007 4:41 AM
Thought I would install the Fenton intake & headers this evening. The intake will sit flush against the head o.k., but when I went to install the headers, I noticed that the raised areas, like ridges, in the gaskets, in-between all the intake & exhaust openings, prevented the headers from going on flush. What should I do? Seems like if I put the bolts in, then tightened, the gasket would not seal and leak. I assumed perhaps these raised areas were there so people would put the gaskets on facing the right direction. What have others done? Thanks!
#139569 10/05/2007 4:25 PM
Not sure if it is correct but here is what I did. I cut out the ridges, basiclly turnning the one gasket into three. It's a little harder to get all lined up that way but it worked for me. No problems in the last 4 years.
Others may have a better idea.
George
#139570 10/06/2007 4:53 AM
Thanks George, I had that thought, but wasn't sure. Thats what I'll do. Thanks again.
Bryan
