7 members (Steelonsteel, J Lucas, Wayne67vert, Shade Baby, rfs56trk, greenie-reddy, 1 invisible),
79
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | Thought I would install the Fenton intake & headers this evening. The intake will sit flush against the head o.k., but when I went to install the headers, I noticed that the raised areas, like ridges, in the gaskets, in-between all the intake & exhaust openings, prevented the headers from going on flush. What should I do? Seems like if I put the bolts in, then tightened, the gasket would not seal and leak. I assumed perhaps these raised areas were there so people would put the gaskets on facing the right direction. What have others done? Thanks! | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Not sure if it is correct but here is what I did. I cut out the ridges, basiclly turnning the one gasket into three. It's a little harder to get all lined up that way but it worked for me. No problems in the last 4 years. Others may have a better idea. George | | | | | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | Thanks George, I had that thought, but wasn't sure. Thats what I'll do. Thanks again. Bryan | | |
