1 members (tclederman),
94
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 6 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 6 | Hey all, this may be an incredibly dumb question, but I can find anything about it on the interwebs... I ripped out all of my 47 GMC brake lines when I first picked her up and now it is time to replace them! Classic Parts and LMC only have brake line kits for half-ton short-beds and three quarter ton long-beds... unfortunately I'm working with half of each... a half-ton long-bed. Does anyone know if the three quarter long bed would have had the same brake lines as the half-ton long-bed? Thanks!
------------ 1947 GMC half-ton
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Good morning! Not sure about the differences between the long bed and the 3/4 ton long bed but I have great success with Inline Tube for pre-made brake lines. https://www.inlinetube.com/?gclid=C...IBQoi2O4ws83pQOQY3bdR5pvL1hoCXGgQAvD_BwE
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jan 2021 Posts: 6 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 6 | Thanks TrknGMC! I will look them up!
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It is very easy to make ones own brake lines, CuNi line is easy to end and flare. Tools are reasonably inexpensive. A good skill to learn, won’t have to wait on someone else. Cheap to replace if error made.
Ed
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I've heard more people refer to long bed and short bed half ton trucks, A-D series. I always thought all half tons in the A-D series were 116 inch wheel base, all the same length box. | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I mostly agree with Ed, I’ve done my own brake lines. However there is a lot of trial and error with doing your own brake lines. Sometimes you have to decide what your time is worth verses buying a complete kit that’s ready to install.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | There's info on the parts list for lengths of brake lines in various positions. Not hard to fab your own lines. Here's the link: Brake Line illustration The following pages have line lengths for various models and years.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 49 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 49 | I'll through in my two cents, INLINE TUBE like said above.
Ask a question if you need a answer! Resting up on Mon-Fri from Sat and Sun.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, Inlinetube - an excellent company that makes excellent brake lines. They made a very nice set for my 1954 3104 Hydra-Matic. I sent them my lines - they wanted to keep them, because they had never seen them. Those SS brakes lines/fittings were an excellent fit. I used Permatex® Nickel Anti-Seize Lubricant. | | |
