1 members (Otto Skorzeny), 58 guests, and 3 robots.
Topics128,022
Posts1,055,381
Members48,422
#139490 09/27/2007 2:08 PM
Is there a performance aftermarket water pump (not electric) out there that is a "bolt on" to a '61 235?
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#139491 09/27/2007 11:04 PM
What's the reason the stock one can't do the job?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#139492 09/28/2007 3:28 AM
It's just a question about availability of bolt-on replacement that might be a more efficient...not a condemnation of the stock pump.
Steve G.
#139493 09/28/2007 3:53 AM
I know of nothing other than the original pump, or an older 216 pump used with an adapter plate.
Grigg
---All pictures---
#139494 09/28/2007 3:54 AM
V
V Offline
Isn't the limitation on the water pump is the size of the water hose outlets? It seems to me no matter what water pump you have those 5/8"(?) hoseoutlets are going to be all the flow you ever get.
#139495 09/28/2007 3:58 AM
The hose coming off the thermostat housing is about 1.25" or so right? And the lower hose slightly larger I think?
I don't see them as being restrictive.
Grigg
---All pictures---
#139496 09/28/2007 4:13 AM
V
V Offline
You are correct. I was thinking of the heater hose outlets that come off the water pump. The restriction might be the smallest part where the propeller is fit against the block/head in a 216 and the adapter plate openning.
