5 members (Hotrod Lincoln, fonz8261, baldeagle, walter74, 1 invisible), 97 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#1394852 01/29/2021 6:55 AM
Hi I just got a 1952 Chevy truck, it’s a project but it’s in decent shape. Want to make it my daily. Can’t wait to start asking questions and start on it.
Welcome to the 'Bolt. smile
Looks like you got a good one. thumbs_up
Welcome. Looks like someone had a good start.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
AD Addict & Tinkerer
Welcome to the “Bolt”! Wow, nice truck! Looks to be rust free and a great start. See you around the garage!
Phil
Project Journals
Stovebolt Gallery Forum
Welcome to the Stovebolt madness. There is no cure! shake
Former Workshop Owner
Hello Atomic52, your truck looks solid, nice find. thumbs_up
FYI: Starting in '51 the doors had wing windows. It looks like yours were either removed, or the doors have been swapped with pre '51 doors. A lot of builders do that so they can install single glass for a simpler build and a cleaner look.
Welcome to the Stovebolt.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I think there is some assembly required ,nice truck
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Welcome to the Stovebolt. Consider yourself at home now! Nice catch and its a 5 window.
Just ask any questions in the garage forums and we'll do the rest. Thanks for posting the pictures.
........there seems to be quite a few bolters here from CA. so keep a watch for them. You may have a bolter buddy next door!
The doors are ‘52 as you can see the bolt hole for the front of the handle in the door. As for the wing windows, if you look closely, you can see with the absence of the window channel that the window has been removed.
Phil
Project Journals
Quote
That explains it. Thanks for pointing that out.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
welcome to the 'bolt. It looks like a great start to a daily!
Another quality post.
Real Trucks Rattle
Welcome, that looks like a great solid find. Just curious what direction you're going with the motor/drivetrain for a daily driver.
Sorry about the absence, but I’m back. I want to run a 235 with an open driveline, maybe an S10 T5.
