2 members (Bill Hanlon, 52Carl), 87 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
Hi there,
Wondering if anyone has a Gm parts catalog that has any part number info for the bendix hydrovac 374000.1955 Chev 2 ton hydrovac.
Trying to track down one specific seal that originally used to be labeled a leather push rod seal. They have been replaced with rubber seals in rebuild kits. I've attached the hydrovac schematic the seal is labeled as #16 (Seal, push rod leather)
i have attempted to find a seal according to shaft and bore size although nothing has turned up yet. can't locate the seal I need. I know these seals are out there. But where !?
Maybe a bendix part number would get me closer to finding the seal?
2 Offline
leather was good enough for the original why not make one with leather scraps
I find in situations like these that I usually make two or three by the time they turn out good
Like pancakes the first is always a throwaway
-s
I agree, an old leather belt and a new razor blade will get you there after a few tries. I have done a similar thing with the leather seal in an old WW2 bicycle pump (they usually were in the jeeps and motorcycles along side a patch kit)
62' GMC Fleetside 3/4 ton 235 4-speed.
Time makes fools of us all.
The thought had crossed my mind but I imagine the original leather seal was built into a casing that could be pressed into the bore.
Still searching for bendix part numbers and superseded part number
Google Hydrovac rebuilders and see if they will sell you the part. Not to long ago someone here on the Bolt had the unit rebuilt and named the company, do a search and check them out.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Noonan There is an outfit in Evansville Indiana 2 guys who do nothing but brake boosters. I talked to one of them about one of my boosters and I think they might help.I would guess any of the big parts stores would know them,went there once for school bus drums it was wall to wall pallets of big drums.
Thanks guys I have made some calls. Tried Harmons classic brakes, I'll never call them again.
Definitely will check out the booster re-builders in Indiana.
Try these guys. Not sure if they will sell you the parts or want you to send them the unit to rebuild but would be worth a phone call. They relined all my shoes and did a great job.
https://www.brakematerialsandparts.com/
Cardone industry.com. They rebuild hydrovacs. I don't know if they sell parts but it's worth asking.
I found the part # !!
Bendix - GM - 372301
Crossover - National - 712022
shaft: .313
housing bore: .691
width: .313
Thanks again for all the help !
I attached some pictures in case any one else needs to search this stuff out . All of the information in the attached pictures came from the link below.
http://www.gmpartswiki.com/getpage?pageid=211050
