0 members (),
122
Mod | | | Forums66 Topics128,131 Posts1,056,727 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | So I'm in the final stages of assembly with the driveline on my 49 3/4 ton. I've been looking at the output shaft u joints on the transmission and wondering how they get lubricated. Do they just catch some gear oil splash from off the speedo gears? Should i be pulling apart the assembly to grease them while i have the torque tube off? I never pulled them apart when i rebuilt the transmission because they felt very smooth, and also because i had a hard time finding a replacement online.
Had a hard time finding much for info on this joint in both the manual and online. Thoughts? Thanks | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | A 3/4 ton is an open drive line right? All my trucks have a grease nipple on each cross, a couple pumps and it squeezes out each cup. | | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | It's enclosed up until the steady bushing. The u joint in question is covered by the torque tube and the transmission housing. No grease nipples | | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | On my half ton model gmc 9300 with sm 420 the back housing at the back of the transmission has a small plug to fill gear oil in the bell for lubrication for the u joint .the service manual should tell you how much to put in . | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Thorens Stuff like that depends on afog of oil that is generated when moving it must work they are still there ! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lubrication of the enclosed u-joint with an SM420 transmission.The lubricant addition hole is on the upper right side of the SM420 transmission. transmission lubricant additions - up to the hole, if lubricant oil is not warm - 1/2" below the hole if the lubricant oil is not warm To speed things up in filling a empty "cold" SM420 transmission, I take out the gear lever and fill through the top until the lubricant comes out that hole on the upper right side. (put a drip tray under the transmission to catch the "overfill") | | |
