1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#139270 09/11/2007 3:24 AM
Apprentice
Apprentice
Just playing with the idea of a turbo on my stock 235!Sick of my Rochester leaking!Has anyone done this with boneyard parts?If so off what engine?I was thinking of maybe a T-Type 3.8 Regal or Gran National.Also thought of maybe a small Izusu cabover diesel.My brother is a tuner guy and came up with the idea.Just an idea but am really interested to know .Thanks Al
"What Dirty Scoundrel Stole The Cork From My Lunch" W.C. Fields
#139271 09/11/2007 3:42 AM
Lots of info at inliners.org on this. There are guys who do it. My dream project is a turbo or supercharged 302 in a 30's GMC hotrod pickup.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#139272 09/11/2007 3:44 AM
Fun idea. There are books available that detail do it yourself turbo charging. I can't give you any titles, but I know I've seen them on the shelf at the bookstore...
#139273 09/11/2007 4:02 AM
I think a blower would be better! grin
Bill Burmeister
#139274 09/11/2007 6:49 AM
Apprentice
Apprentice
I agree with the blower but when the last time you saw one in a junkyard! My next question is doesnt "inliners" cost?With all the info out there I really dont want to pay for it !Thanks for the answers and Please keep them coming Al
#139275 09/11/2007 9:58 PM
No cost to become a part of their forums. You need to register but participating in their forums is free. They are a great source for additional info....almost as good as the "Stovebolt".
Dave
http://www.inliners.org
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#139276 09/12/2007 3:55 AM
What i was thinking was to use one off of a supercharged GM 3.8 V6, say from a Pontiac grand Prix GTP. It looks to about the right size to mount easily, and should be easy to get one out of a junked car. Or, if yoe get REALLY lucky, you might just find an original S.C.o.T. blower from the '40s/'50s, though the Chevy versions are extremely rare, and not being reproduced like the Flathead ones are.
Bill Burmeister
#139277 09/16/2007 8:32 PM
If you are going to do a turbo on a stovebolt, I would suggest going a step further and installing fuel injection, then you can control timing and boost with the computer too.
I've got a Jimmy 302 in my garage that I'm working on gathering the parts for- I'm going to do a MegaSquirt II fuel injection on it, using mostly GM parts, get it running well, then add a 4-71 blower and volvo intercooler to it. I figure with stock compression it ought to take to the boost pretty well. Its going to replace the 261 in my truck.
Paint & Body Shop moderator
#139278 09/29/2007 1:12 AM
There is a guy on youtube.com that has a turbo on a 261. Search "turbo 261"
The installation is a bit primitive, but it seem to be working.
Personally, I would put a turbo or supercharger on a 261 before I would on a 235, as the 261, from what I have read, has a beefy lower end.
#139279 09/30/2007 12:44 AM
Personally I would choose a turbo over a blower. My v6 turbo in my regal makes upward of 400hp and over 450ft/lbs of torque at 25psi of boost. And alcohol injection allows me to do all this on pump gas. I won't promise that on a 235 or 261, but it will be easier for you to make more usable HP and torque for the street with a turbo. You compare the supercharged torque ratings of a 231 v6 to a grand national engine and the turbo engine makes over 100ft/lbs of torque than the supercharged version. Just some food for thought.
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
#139280 09/30/2007 5:37 PM
If port injecting a 235, I think the siamese port could get you into trouble. It's possible for a given cylinder to take more than it's share of the shot from two injectors, resulting in the other one being way lean.
You could fudge a blow-thru TBI injection setup with junkyard GM components, if your guy is pretty good with the tuning side. He has to increase the Accel-Enrinchment to make up for wet manifold operation, among other things.
mv
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#139281 10/18/2007 4:25 AM
1 Offline
read "maximum boost" by corky bell. it is available at most book stores, it is a must read for anybody interested in turbo systems
2003 ford lightning
1959 chevy 36
#139282 10/18/2007 9:21 PM
Turbos, Blowers, on a 235??? Only if it's just for the fun of it...
Better buy a case of crank shafts while you're at it. :hammering:
~Jim
#139283 10/23/2007 5:00 PM
Junior Member
Junior Member
^^^ The 216 and 235 most likey will not be able supply enough oil pressure for turbo.
#139284 10/25/2007 7:17 AM
Junior Member
Junior Member
A.Grahm Bell in his book on 4 cycle engine tuning has a section on how to port siamesed ports to minimize or eliminate charge robbing
#139285 10/25/2007 12:44 PM
Hi Brad,
does that book deal with charge robbing and port fuel injection? I may have to find a copy.
IMO, the old chev six may not rev, but it could make some serious torque numbers with a well matched turbo. Another approach may be to blow thru a TBI unit. Programming required! There are different accelleration enrichment values needed, because of the wet manifold. I would think you'd need to crank it up, compared to port EFI.
MV
Mike Vee #330247 10/30/2007 12:39 AM
If you are looking for easy supercharger, then look at the turbine types such as Paxton, Vortech, procharger, etc vs the positive displacement versions such as magnacharger, eaton, etc. The turbine chargers have the compressor side of a turbo with a gearbox on the input side driven off of the crank pulley.
Using a Turbo on an I6 is not new, I see a large number of 194/230/250/292 turbo exhaust manifolds on Ebay and other web sites, however not the 216 or 235. I am not sure that the 216/235 would have enough oil pressure to make the turbo live.
depending on your compression ratio, you may want to stay relatively low on boost anyway, say between 6 and 12psi unless you are building a boost engine from scratch
In either event, you will want to go with fuel injection over carburation for tuneability.
just my $.02
Scott
gofstbuick #330839 10/31/2007 2:46 AM
Go to Amazon.com and search on "Corky Bell". He has written some of the definitive books on boost, "Maximum Boost" and "Supercharged". Your search will also give you books that use him as a reference.
You can actually interact with the Cork-monster online. He hangs out at the Miata.net forum in the forced induction motor section. That's his "bag", turbocharging Miatas. I agree with 4onthefloor, if you can fuel inject it, you will have a lot more control over the fuel and timing, and that's what will keep the engine together and not go blooey. I run a system that he engineered most of the hard bits on my car, 240 rear wheel horsepower from a 97 cubic inch motor, still streetable and docile until you squish the right pedal.
R-Bo
1966 GMC 305V6 in the family
4ontheFloor #332475 11/03/2007 4:07 PM
4onthefloor,
I would be interested in more data on the injection system for a 235. IE, whats available, cost, supplied ect. How about an e-mail plz?
dgerth
16525
