13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible), 123 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
#139262 09/10/2007 5:43 AM
Junior Member
Junior Member
1 Offline
Where is the best place to hook into the cooling system for the temp probe that controls the electric fan?
Mine is hooked to the lower rad tank and does not seem like the right place to me.
I would think upper in the cooling system be the place ..heat rises ???
1952 Chevy Shortbed
Photos in Photobucket
2 Offline
You can go up to NAPA and get a thermostat housing with a fitting for the sensor pretty cheap. That is what I did with my 235.
Tom
Riding in the Passing Lane
I put mine right by the upper hose. It works good.
1972 Chevy c10 Cheyenne Super
''get a thermostat housing with a fitting for the sensor pretty cheap''
for that matter you can drill and tap a hole for a sensor in your thermostat housing
Jim & Caroline
I think Rick has the type of sensor with a probe, kind of like older A/C used. They go in the core of the radiator or taped to the upper hose.
Junior Member
Junior Member
1 Offline
Wrenchbender is correct.
Thanks for the advise. I will be changing the set up to the thermostat housing
If you move it to the thermostat housing, make sure it goes on the radiator side of the stat, not the head side.
Paint & Body Shop moderator
