| | | Forums66 Topics128,282 Posts1,058,490 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 72 | Working on a 46 1/2 ton 3 speed transmission. Does anyone know a source for a shim for the main drive gear? Thanks. Larry
Larry
46 Chevy 1/2 ton stake - family truck for 78 years USAF 75-81
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Runnjump you used to get thrust washers dimpled type with a small parts kit also had some shim stock type. After a few jobs you would have spares, maybe someone will chime-in with some.I think later ones will fit it,also modern (Muncie 4 speed early 7/8 shaft type) may work . | | | | | Joined: Jan 2006 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 72 |
Larry
