Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Drew54, Otto Skorzeny, Maybellene, klhansen, 2-Ton, Bristol's Tree S, 1 invisible), 118 guests, and 2 robots.
Topics128,281
Posts1,058,488
Members48,490
#1392132 01/11/2021 12:25 AM
Working on a 46 1/2 ton 3 speed transmission. Does anyone know a source for a shim for the main drive gear?
Thanks.
Larry
Larry
46 Chevy 1/2 ton stake - family truck for 78 years
USAF 75-81
Runnjump you used to get thrust washers dimpled type with a small parts kit also had some shim stock type. After a few jobs you would have spares, maybe someone will chime-in with some.I think later ones will fit it,also modern (Muncie 4 speed early 7/8 shaft type) may work .
Thank you fixite7!
Larry
USAF 75-81
