2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13913 01/15/2005 2:34 AM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | My motors manual says max oil pressure for a 1955 235 is 35 psi. On a cold start up I have a 30 psi reading, and after fully being warmed up have 5 psi at idle and between 10 to 20 psi depending on engine speed. The engine is rebuilt and a new oil pump was installed. Are these oil pressure readings correc or should I have more pressure.
thanks John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
#13914 01/15/2005 2:44 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | That's low. Are you using your original gauge? You might want buy an after market oil pressure gauge just to check it. I had an '75 Dodge 360 that went down to 5 psi at hot idle before I sold it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#13915 01/15/2005 2:57 AM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I have tried 3 differant mechanical gauges with the same readings on all three. 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
#13916 01/15/2005 3:11 AM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | My 49 216 carrys 10+ at idle. what oil vis are you using? | | |
#13917 01/15/2005 3:14 AM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I am using Valvoline 30w. I will try try 40W (Wolfshead brand) tommorow.......... 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
#13918 01/15/2005 3:02 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think that you want to use heavier oil to make the pressure reading look good, that is a mistake. If the pressure is on the low side, there must be a reason. | | |
#13919 01/15/2005 6:16 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | I agree, the specs for my 49 says 20 weight so I would be careful with the heaver ones, I was thinking you might have been using a multiweight. | | |
#13920 01/15/2005 6:26 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Unless bearing clearances were set way to loose I would say the oil pump relief valve is stuck open.
See the USA in your vintage Chevrolet! My Blog | | |
#13921 02/09/2005 4:01 PM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Hello All; thanks for the replys, so her is an update: I took the lifter cover off and checked the oil line that goes to the head and found a kink in the line, so I go to the hardware store to get some 3/16" line, and that was a no go, so off to NAPA (should have gone there first. Anyways, I took a shaft from a spare distributor and attached it to my drill to prime the engine, VIOLA, instant 35 psi, and with the drill slowly turning I had 20 psi (55 degrere day, oil cold and using 40W) with the oil line disconnected. So my question is, why do I have higher oil pressure using a drill, with the engine not running? I would think the oil pump would prime itself with the engine running....... 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
#13922 02/10/2005 12:07 AM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | i am not an expert but i believe that kink you were referring to is suppose to me there. i read that somewhere in this forum once upon a time. i have a 235 out of a 62 chevy and i have a kink in the line but then i also struggle with any oil pressure at all at idle.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#13923 02/11/2005 9:55 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The oil thins out within about a minute of startup, so comparing the maximum pressure with your drill is tricky. On my 216, turning the oil pump with the drill makes the drill work pretty hard. If you don't experience that with the drill something is definitely wrong . | | |
#13924 02/12/2005 1:34 AM | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | thanks for all the replys. Anyways what weight oil should I use, 30 HD, 10w30, 40hd, 20w-50............. And what should my oil pressure be at idle for a '55 235. Idle being 550 -600 rpm's Thanks john Gott  :rolleyes: 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
#13925 02/12/2005 1:38 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 5 psi at idle is enough,but as soon as the engine speed is increased,the pressure should go up to at least 25 psi when warm.These engines will run for a long time with low oil pressure if ya don't push hard. A 235/261 with a good oil pump and proper bearing clearances will have when hot,30-35 psi at idle and 40-45 psi going down the road. If your engine has such low oil pressure,it either isn't rebuilt or was a quicky job or the machinist booted the clearances.Use a heavy enough oil to maintain a reasonable oil psi when hot. | | |
