9 members (rfs56trk, Mike in Sycamore, Nick in Manitou, Otto Skorzeny, Bill Hanlon, Charles in CA, Gray_Ghost, 2 invisible),
90
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | Did the muncie 4 speed transmission come painted from the factory? Is so, what color. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | I've never found any paint on an SM-420, they have always been bare cast iron under the grease and oil. If I was restoring one I'd either paint it semi gloss black or cast iron gray. The gear shift lever (cane) would be black. Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | oops - I deleted incorrect info - thanks for the "heads up", Mike.
I dimly recall that the SM420 was painted black on my 54/55 GMC Z-Series 350 COE (but, it might have been real dirty and it might have been a replacement transmission)?
Some oldGMCtrucks members indicated that replacement transmissions might have been a different color than an original-equipment SM420.
Sorry about my incorrect-information link.
Last edited by tclederman; 01/09/2021 6:52 PM. Reason: changed/deleted incorrect informationn
| | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Tim, the OP was asking about transmission colors, not engine color... Mike B  | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | Semi gloss black was what I was thinking. Thanks guys | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chevy's till I die Dont think they painted those gear boxes like they said these trucks were for work not show !!! | | | | | Joined: Jul 2020 Posts: 112 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 112 | As far as i know, the trans itself was not painted, the only part that was painted would have been the pto, red was one brand and black was another, muncie and chelsea i believe.
THE BLACK VIKING 1958 Viking 60 ~ my new toy hauler My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60 Keep 'em rollin fellas!
| | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | As far as i know, the trans itself was not painted, the only part that was painted would have been the pto, red was one brand and black was another, muncie and chelsea i believe. PTO's were aftermarket and installed by the dealer/owner for their intended use, so they have no bearing on what color the trans should be. Mike B  | | | | | Joined: Dec 2020 Posts: 104 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 104 | Our 1956 6400 4 speed does not appear to have been painted. I don't know if it is original, but guess that it is. The engine was probably a dealer replacement as it has no serial number, and January 1958 casting. Also, the block and head are unpainted, but oil pan, valve cover, and side cover are yellow.
Steve | | |
