0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Is there a dedicated female bullet terminal for an AD brake light switch? I have tried a 14g (too loose) and a 16g (too tight). Once I force a 16g terminal on it is then too loose. I'm using generic bullet terminals and maybe the factory had more spring to them. I might have to thread the male bullet terminal on the switch and convert to a ring terminal with nut. I checked Classic with no luck but maybe another supplier may offer them. Thank you.
Evan
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yes. I happened to find the local Bumper to Bumper had them in stock. The younger guys up front had no clue. I have to cut them a bit of slack because until then I didn't know either.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | There are multiple size/diameter "bullet" terminals. Find the ones that fit snug! | | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | These are close to stock ,fit good made for what you need. Dorman HELP! 85845 90 Degree Sndg Unit Pigtl for sale on Amazon, Napa and any good Flap store. https://www.amazon.com/Parts-Master-1-Wire-Pigtail-Connector/dp/B00B663U3Q
!956 Gmc Napco 4x4 Factory line built .
