3 members (TeW, Hotrod Lincoln, homer52), 65 guests, and 0 robots.
Topics128,049
Posts1,055,638
#1391467 01/06/2021 3:35 AM
Is there a dedicated female bullet terminal for an AD brake light switch? I have tried a 14g (too loose) and a 16g (too tight). Once I force a 16g terminal on it is then too loose. I'm using generic bullet terminals and maybe the factory had more spring to them. I might have to thread the male bullet terminal on the switch and convert to a ring terminal with nut. I checked Classic with no luck but maybe another supplier may offer them. Thank you.
Evan
Ex Hall Monitor
Ex Hall Monitor
Yes. I happened to find the local Bumper to Bumper had them in stock. The younger guys up front had no clue. I have to cut them a bit of slack because until then I didn't know either.
There are multiple size/diameter "bullet" terminals. Find the ones that fit snug!
These are close to stock ,fit good made for what you need.
Dorman HELP! 85845 90 Degree Sndg Unit Pigtl for sale on Amazon, Napa and any good Flap store.
https://www.amazon.com/Parts-Master-1-Wire-Pigtail-Connector/dp/B00B663U3Q
!956 Gmc Napco 4x4 Factory line built .
