Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (1954gmc9314, Hotrod Lincoln, cmayna, ndkid275, latroca52), 199 guests, and 3 robots.
Topics128,292
Posts1,058,590
Members48,492
Another leak. Long story, but I'm missing the gasket that goes between the upper and lower parts of the housing. It has a 2 1/2" center hole, for the larger 261 bypass thermostat, and the off center bolt holes. Does anyone know where I can quickly find one? Maybe I have to make my own? I have found expensive complete gasket sets that seem to have one. Other vendors improperly offer just that gasket for the 235 housing with the smaller diameter thermostat. And they say it's for a 261😡
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Quickest way is to Make your own.
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
I would make a template out of cardboard, and then buy a small roll of blank gasket material.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
H Online: Content
I've made untold hundreds of gaskets with nothing but a piece of gasket paper and a ball peen hammer. Use the housing as a template and the ball end of the hammer to gently tap out the shape of the gasket.
What Jerry said. Never had proper gasket paper, but a cereal box or even a hat box (for those who wear hats and not caps) has the proper thickness and fiber to make gaskets. A ball peen hammer to cut the gasket out of the material of choice then the proper empty cartridge case to punch the bolt holes out. Used to be common practice.
RonR
RonR
1970 340 Duster
1964 CJ5
H Online: Content
I went "high tech" a few years ago and bought a well-used set of gasket punches from Ebay. With a little sharpening, they're good as new. A slab of hard maple or red oak is just the right hardness to get clean cuts without dulling the cutters excessively. The thin cardboard backing piece from a pad of scratch paper is about the right thickness for most gaskets like thermostats, fuel pumps, etc.
Moderator
Moderator
2 Offline
Made one years ago for a thin gasket need. Rear cover of a Playboy Magazine was just the right thickness.
I too have made a lot of gaskets over the years. A 4x4 cut off about four inches long and stand with the grain up, works good as a chopping block for hole punches or cartridge.
Like Jerry said, take a ball peen hammer and tap out the housing pattern, then cut it out with a sharp utility knife.
If you have a set of hole punches, all the better.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Thanks guys! Love the cartridge idea! Gasket is done. It's good. I did spend $12 on some felpro gasket material.
My Webshot Photos]
