5 members (Oswald, 2-Ton, 1955 1 Series, Peggy M, Hotrod Lincoln), 75 guests, and 2 robots.
Topics128,089
Posts1,056,352
Members48,442
#139148 08/28/2007 7:09 PM
When I bought my truck it was already lowered (the wrong way). The springs were heated so bad they look like twisted up pretzels. The stance of the truck is pretty good but ride quality suffers. I am planing on doing all the suspension at one time (bushings, ball joints, end links, springs, shocks ect..) But what I am not sure of is how far they lowered this truck.
From the ground to the bottom of the front wheel well is 26 1/2". The ground to the bottom of the rear is 24". Would somone mind measuring their truck (lowered or not) and let me know where it is at (if lowered please mention your drop). Thanks a ton.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
#139149 08/28/2007 10:47 PM
Are you referring to the 63 truck? Someone will chime in here. Mine is a 51 so I'll sit this one out. Except to say, all I did was to swap the rear springs from above the axle to under, and the front is a MII which lowered the front 2".
~Jim
#139150 08/29/2007 8:49 AM
I apologize, looking for 63-66's.. Thanks though smile
#139151 08/29/2007 1:49 PM
Well I am about 2inches lower when air bags inflated. about 8 inches with no air and when the mufflers hit the pavement and rear gas tank is scraping. 62 truck with 68 front suspension
(no I don't drive it like that)
#139152 08/29/2007 5:55 PM
Would you mind taking a measurement at full ride height? I'm trying to guage how low the truck is now compared to stock.
Shaun
#139153 08/30/2007 2:17 PM
Junior Member
Junior Member
Super,
I measured my '62, and it is stock height as far as I know. I measured from ground to bottom of the fender lip 29 inches both front and rear. Truck has stock springs and T-bars, so they may have settled a little since '62.
Mark
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
#139154 08/31/2007 10:38 PM
By the way you measured I am 24 inches at driving height on all 4 corners.
#139155 09/01/2007 5:50 AM
Mag, Thanks for the stock numbers.
Gazim, Your saying at 24" you are 2" bellow stock? That front must be burried!!!
#139156 09/01/2007 6:14 PM
Only when I let the air out. Otherwise, 24" still rides fine.
