5 members (UtahYork, BC59, KEVINSKI, dt235sd, 1 invisible), 94 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
Would anyone know the thickness of a new clutch disc, in this case GM 3835453 (10-3/4") fitted to trucks and cars between 1938-1953. Thank you.
Philippe Jeanneau
Clutch Facing thickness is between .137-.143" for the 10-3/4" clutch...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Hello Mike,
My clutch disk thickness is between 0.330-0.333 or (8.38-8.45mm) You can still see some numbers WFI 101059? Wonder if it is even the right disk. Somewhere I saw that a clutch disk for a 235 engine has a light blue line painted for identification... This one has light blue paint on one side of it, and now I wonder if someone thought it would be an upgrade...
Your measurements are in the 3.47 to 3.63mm, that is quite a difference... In which case, I probably should just leave it alone and only replace the throw out bearing just to be safe...
Philippe Jeanneau
There's a difference between clutch FACING thickness and disk thickness. So Mike's number would be doubled (facing on each side) plus the thickness of the metal disk backing.
Thank you for the very important clarification... I measured everything again and got 0.142 or 3.61 mm, so it appears that I am still within specs...
Philippe Jeanneau
2 Offline
How thin would a worn out clutch be?
For future reference
If I measure mine I would like to know if I’m at 60% or 20% for instance
-s
2 Offline
it has grooves, so when the grooves are gone that is considered end-of-life?
not much life in these things i guess, don't ride the clutch smile
-s
Mine has grooves also, but they're not very deep... I might just get a new disk provided I can find one that is made in U.S.A...
Philippe Jeanneau
If the rivets are shiny from rubbing on the flywheel or pressure plate, then the disk is definitely worn out. If there isn't much depth to the rivet heads left, I would replace the disk.
That tells me you have a new or almost new clutch in your hand as a new face can range in thickness from 0.137" to 0.143".
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Here are a couple shots of the clutch disc...
Philippe Jeanneau
AD Addict & Tinkerer
Judging by the printing still visible on the disk face, its almost new!
Phil
Updated to: ā€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
Flywheel behind looks new too.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
