Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (WICruiser, fonz8261, Guitplayer, 1 invisible), 49 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#1388040 12/12/2020 6:59 PM
Took it apart clean, worked fine for a while. Some time back to zero. Some time at twenty work off an on. You wrong lube.
simonbolivar #1388042 12/12/2020 7:09 PM
Gotta say Simon, that was kind of random. Did you intend to post it on another thread?
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
simonbolivar #1388045 12/12/2020 7:29 PM
I would disconnect it until you can take a look at it
simonbolivar #1388126 12/13/2020 5:48 AM
Fox Offline
I had to completely disassemble mine when it started bouncing around the gauge. It wasn’t the cable, it was the lube on the gears inside. It was 70 years old, crusty, hard, and of course it was causing the needle to skip and jump all over the place, not to mention making a terrible grinding sound to boot.
Cleaned it, lubed it, and it works flawlessly now.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
simonbolivar #1390623 12/31/2020 2:29 PM
Question to all...What lube is bestfor speedometer and how to get it to it in the truck cable is OK??
simonbolivar #1390750 01/01/2021 5:20 AM
Fox Offline
I used red axle grease on my speedo which is working great.
My speedo cable was new so I didn’t lube it. I have heard guys use graphite lube or pour thinned gear oil down the coil. I haven’t tried this and would wonder if any gear lube would be thrown outward near the ends?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1391121 01/03/2021 8:50 PM
Fox Remember at the swapmeet that old guy would have a speedometer running there real smooth?? I never tried his snake oil but I thought it would be something thin to work when its cold. My 51 6400 speedo was not working ,had a cable so oiled it put it in speed works miles work 2 speed axle box works. Only trouble is hand rubs on the glass but it will fight its way up there. I felt like thats pretty good for 70 year old equipment !
Moderated by  ndkid275, Phak1
