0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1390537 12/31/2020 1:28 AM
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/26195/filename/s-l1600 (11).jpg[/img]When I bought my truck It had a 235 in it with this air cleaner on it. I have looked for any info on the OEM air cleaners but not found much. I want to go back to the 216 engine that I found but was wondering if this is the right one for my 47 with the 216.
1947 3600 Chevy
that is a later car air cleaner like my 60 chevy had !
Lumber',
That looks like the mid-late '50s style that was common on passenger car 235s, so I'm thinking it probably came with the later 235. Image attached is from the '57 car assembly drawings. Having said that, no reason it wouldn't work on a 216 that I know.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
There are two types associated with your 216 originally, open element and oil bath (2-sizes).
https://www.flickr.com/photos/advance-design_parts_co/8250844197/in/album-72157632186114015/
Oil bath type, referred to as a 1-pound (Option 216D, $3.65 installed).
https://www.flickr.com/photos/advance-design_parts_co/17057189590/in/album-72157651718017649/
https://www.flickr.com/photos/advance-design_parts_co/8129088452/in/album-72157631867396207/
Oil bath type, referred to as a 2-pound (Option 216E, $4.70 installed).
https://www.flickr.com/photos/advance-design_parts_co/17057189770/in/album-72157651718017649/
https://www.flickr.com/photos/advance-design_parts_co/18996552503/in/album-72157631870734114/
Both the 1-pound and 2-pound are listed for the 3100 Series truck in 1947 price guides and 1947-48 Salesman Truck Data Book.
Thanks, I was thinking it came with the later 235 implant. Although my 235 was a Truck engine not from a car. I'll have to keep my eye out for a proper air cleaner.
1947 3600 Chevy
Post an ad in the Swap Meet, someone may have an extra. They appear with some regularity on eBay but are pretty pricey at times. The open element type can run as high as $200 on some listings so be aware.
Just to add here, the 55-56 car air cleaners were a clamp type cleaner and the carbs for those motors did not have the cross bar and stud arrangement that the 57 and later carbs did. In 57, the pass car had a lower hood profile then did the 55-56 so instead of the clamp on the air cleaner, there is a recessed area on the top of the cleaner for a stud and wing nut and the carb has a cross bar for a stud. This set up helped get the lower profile hood to fit.
Mike
