8 members (1954gmc9314, dt235sd, 55shaker, 2-Ton, Hotrod Lincoln, Bill Hanlon, ShopRag, Hush),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,274 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I finally found a Carter updraft 2075s. Does anyone know where I can find float level specs? I've got a dead spot and starting with the float.
1958 Chevy Grumman Olson step van
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Maybe this will do till something better shows up.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Has the level. Thanks pal!
