3 members (WICruiser, tclederman, Donf), 196 guests, and 1 robot.
Topics128,081
Posts1,055,959
Members48,430
#1389456 12/22/2020 6:59 PM
Out in the workshop (barn), this a.m. New rebuilt generator (six volt), and new belt which I don't have the time to center well. Parade was at 1;00. Looked around to find my belt dressing, no luck. Full can of Walgreens Sun Screen. Did not work at all on two of my little Irish grandchildren so I put it on the shelf, don't know why. Put some on the belt instant quiet. Bracket still needs to be adjusted later, super quiet plus after running for 2 hours made my radiator hoses very shiny and appears to be permanent. See what happens in a few months of Central Florida heat. Looks good and no squeak. Go figure. Doc.
Insomniac
Insomniac
I heard sun tan lotion was a necessity in Florida. headscratch
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
I don't have sunscreen. What do you think about Preparation H?
1951 Chevy Panel Truck
Bar of soap used to work very well when I worked at a shop 40 years ago. Just touch it to the moving belt (carefully) Not sure how easy it is to find soap without weird stuff in it these days though.
All of your comments are true, used Castell bar soap for years, couldn't find it. Oh, here in Florida we use Prep H for mustache wax, it keeps one from licking it. Doc.
Doc.Hall #1389730 12/24/2020 11:42 PM
Ex Hall Monitor
Ex Hall Monitor
DOT 3 brake fluid works as well. Dribble a few drops on the belt as it's running. I have no clue how but I did watch a mechanic in the shop I worked in as a young fellow use it. Shut the squall right up.
Just be careful not to let the brake fluid splash/ spray onto any finished paint, it's been known to lift it!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1389875 12/26/2020 7:00 AM
Mike B smile
Indeed it does remove paint. The guys in the Army shop I ran years ago used brake fluid to remove the primer from replacement flywheels, clutch pressure plates and brake drums. Everything was shipped in primer to prevent rust in storage.
on belt squeal we used to use ru-glyde rubber dressing shut it right up.
Kihansen: now that you mention it an old iron worker i knew said when he was in the army they would get stuff just covered in cosmoline. They expected them to wash that off with GI soap and water. He said they learned how to get carbon tetrachloride that will really cut it ! Years later he was so shaky we had to carry his coffee down in frontto the seating.He would then brace -up and drink it ! That carbon tet may not be to good for you !
Carbon tetrachloride was outlawed because it proved to be fatal with minimal skin contact. The dry cleaning industry had to really scramble to find a different way.
β€˜65 Chevy Biscayne (Emily)
β€˜39 Dodge Business Coupe (Clarence)
β€œI fought the law and the law won" now I are a retired one!
Doc.Hall #1390722 01/01/2021 12:45 AM
2 Offline
I have a few gallons of that stuff on my farm
My dad was still using it to clean small parts when I was a kid
Maybe that’s why I shake so bad, I could have been exposed to it many times as a kid
I need to find a proper disposal place for it and a few other liquid disasters that have collected over the years.
One more thing on the to do list
-s
