0 members (), 80 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1389718 12/24/2020 10:24 PM
I'm considering changing out the hoses in my PCV system. Has anyone had any luck creating a good curvature bend in a rubber hose using heat? I'd like to know if there is a practical method of doing this without it crimping up. Thanks.
Merry Christmas!
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #1389762 12/25/2020 3:47 AM
Nope- - - -don't even consider it. Use 45 degree or 90 degree plastic barbed elbows to make turns- - - -the PCV hoses with bends in them are molded at the factory. Molded elbows are available, however, but you'd need barbed splice nipples to use them.
MarkT #1389770 12/25/2020 8:36 AM
Bend the line out of brake/fuel hardline with rubber ends.
1951 Chevy Panel Truck
MarkT #1389826 12/25/2020 7:42 PM
I've seen a product called Unicoil that you slip over the hose where you want the bend. I'll probably start searching for a connector with an angle that will fit. I've seen a YouTube with someone attempting to bend one by hovering it over a candle but I think it would wreck the integrity of the hose. The end result didn't look that great.
MarkT #1389833 12/25/2020 8:31 PM
You could try bending a piece of round rod or tubing to the shape you want, slip the hose over it with a little non-petroleum lubricant (K-Y jelly maybe?), and dip it in boiling water. There's no guarantee it would keep its shape, but it might start out looking like you want.
MarkT #1389861 12/26/2020 1:05 AM
Years ago I needed a cowl vent drain hose that made a large offset from the nipple at the vent to outside the firewall so rain water would drop just behind the valve cover. I sleeved a piece of soft copper tubing inside the middle of the straight hose and bent it to shape...it's been in there for 40 years. That method might work for you.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
MarkT #1389863 12/26/2020 1:43 AM
Years ago?
Generations ago!
tclederman #1389868 12/26/2020 5:23 AM
Years ago?
Generations ago!
Lol, how true...but that hose still looks good and has held it's shape for all these years!
Mike B. smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
MarkT #1389919 12/26/2020 6:56 PM
I'll report back if I can find a way that works. The boiling water and tubing method might work. Thanks!
MiraclePieCo #1389938 12/26/2020 9:31 PM
That's what I've done. Less likely to fail than hose that has been bent.
BC
1960 C60 pasture art
MarkT #1390014 12/27/2020 4:22 PM
The metal line/rubber end method is how the big rigs got vacuum to a 2-speed rear end. No reason it won't work for a shorter PCV run.
