0 members (),
67
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'm considering changing out the hoses in my PCV system. Has anyone had any luck creating a good curvature bend in a rubber hose using heat? I'd like to know if there is a practical method of doing this without it crimping up. Thanks. Merry Christmas! | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Nope- - - -don't even consider it. Use 45 degree or 90 degree plastic barbed elbows to make turns- - - -the PCV hoses with bends in them are molded at the factory. Molded elbows are available, however, but you'd need barbed splice nipples to use them. Jerry
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Bend the line out of brake/fuel hardline with rubber ends.
1951 Chevy Panel Truck
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I've seen a product called Unicoil that you slip over the hose where you want the bend. I'll probably start searching for a connector with an angle that will fit. I've seen a YouTube with someone attempting to bend one by hovering it over a candle but I think it would wreck the integrity of the hose. The end result didn't look that great. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | You could try bending a piece of round rod or tubing to the shape you want, slip the hose over it with a little non-petroleum lubricant (K-Y jelly maybe?), and dip it in boiling water. There's no guarantee it would keep its shape, but it might start out looking like you want. Jerry
| | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Years ago I needed a cowl vent drain hose that made a large offset from the nipple at the vent to outside the firewall so rain water would drop just behind the valve cover. I sleeved a piece of soft copper tubing inside the middle of the straight hose and bent it to shape...it's been in there for 40 years. That method might work for you. Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Years ago?
Generations ago! | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Years ago?
Generations ago! Lol, how true...but that hose still looks good and has held it's shape for all these years! Mike B.  | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'll report back if I can find a way that works. The boiling water and tubing method might work. Thanks! | | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | Bend the line out of brake/fuel hardline with rubber ends. That's what I've done. Less likely to fail than hose that has been bent.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | The metal line/rubber end method is how the big rigs got vacuum to a 2-speed rear end. No reason it won't work for a shorter PCV run. Jerry
