2 members (Southerntruck, Otto Skorzeny), 120 guests, and 2 robots.
Topics128,110
Posts1,056,242
Members48,437
#1389858 12/26/2020 12:42 AM
found this sway bar for 5'5-59 trucks, wondering if it would fit on my '46 1/2 ton.
If you have one its about the dimension between the link eye holes matching the 46 frame width.
It mounts backwards to normal, ie: onto the I-beam eliminating the need for adding a crossmember.
I love that the design is so outside the norm. photo attached
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
I bet the width is to wide for your '46. Here is the tech tip I wrote up for my '37 https://www.stovebolt.com/techtips/driveline/swaybar/index.html your '46 frame is really close to the '37.
