1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Out in the workshop (barn), this a.m. New rebuilt generator (six volt), and new belt which I don't have the time to center well. Parade was at 1;00. Looked around to find my belt dressing, no luck. Full can of Walgreens Sun Screen. Did not work at all on two of my little Irish grandchildren so I put it on the shelf, don't know why. Put some on the belt instant quiet. Bracket still needs to be adjusted later, super quiet plus after running for 2 hours made my radiator hoses very shiny and appears to be permanent. See what happens in a few months of Central Florida heat. Looks good and no squeak. Go figure. Doc.
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | I heard sun tan lotion was a necessity in Florida.
Gord π¨π¦ ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I don't have sunscreen. What do you think about Preparation H?
1951 Chevy Panel Truck
| | | | | Joined: Aug 2007 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 23 | Bar of soap used to work very well when I worked at a shop 40 years ago. Just touch it to the moving belt (carefully) Not sure how easy it is to find soap without weird stuff in it these days though. | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | All of your comments are true, used Castell bar soap for years, couldn't find it. Oh, here in Florida we use Prep H for mustache wax, it keeps one from licking it. Doc.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | DOT 3 brake fluid works as well. Dribble a few drops on the belt as it's running. I have no clue how but I did watch a mechanic in the shop I worked in as a young fellow use it. Shut the squall right up.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Just be careful not to let the brake fluid splash/ spray onto any finished paint, it's been known to lift it! Mike B  | | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | Just be careful not to let the brake fluid splash/ spray onto any finished paint, it's been known to lift it! Mike B  Indeed it does remove paint. The guys in the Army shop I ran years ago used brake fluid to remove the primer from replacement flywheels, clutch pressure plates and brake drums. Everything was shipped in primer to prevent rust in storage.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | on belt squeal we used to use ru-glyde rubber dressing shut it right up. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Kihansen: now that you mention it an old iron worker i knew said when he was in the army they would get stuff just covered in cosmoline. They expected them to wash that off with GI soap and water. He said they learned how to get carbon tetrachloride that will really cut it ! Years later he was so shaky we had to carry his coffee down in frontto the seating.He would then brace -up and drink it ! That carbon tet may not be to good for you ! | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Carbon tetrachloride was outlawed because it proved to be fatal with minimal skin contact. The dry cleaning industry had to really scramble to find a different way.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) β65 Chevy Biscayne (Emily) β39 Dodge Business Coupe (Clarence) βI fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I have a few gallons of that stuff on my farm My dad was still using it to clean small parts when I was a kid Maybe thatβs why I shake so bad, I could have been exposed to it many times as a kid I need to find a proper disposal place for it and a few other liquid disasters that have collected over the years.
One more thing on the to do list -s | | |
