0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | well im would like to put a toyota steering box in my 53 chev3100 and keep the straight axle, with a 77 firebird tilt colum. i came to the quik reality of how do i hook the box to the colum just a u joint? or do i need a slip joint also? and also do i have to make a shorter drag link?i know i have to make a pitman arm out of the chev and yota.any one out there have any advice like change steering boxes. any input will be very helpful :confused:
gotta love old trucks
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | 53 chev, I cannot answer your questions as I have yet to get that far on my project but would you "clue me in" as to what year Toyota's will work? Thanks for any info and good luck on finding your answer. I know its been discussed here before.....Hmmmm, maybe we should try a search at the top of the page?!! | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | the toyota wreking yard ai got my box said it is a 84 or 85 toyota 4x4 box it will work i have seen kits to do it but cant afford the kit. the starting price is 649 bucks. it includes new pump line's brakets and drag link. im elcheapo and feel i have to make everything myself. if i find more i will post
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The Toyo conversion has been used for years in the 53-56 F100's....I used the same setup with my own custom mounting bracket on a 64 F100 straight axle 460 Lincoln powered truck. It works flawlessly.
I plan on doing the conversion in my 54-3100 and have a couple thoughts on finishing it up. First of all, the box mount fabrication is basically angle iron and matches the angle of the column. Secondly, I've seen (and have a couple pics) of a GM application in my webshots. However, this builder just reused the Toyo pitman arm and bent it to fit. I've cut the Toyo splines off and welded them into 1/2" flat stock (pix) on the F100's and plan on increasing the pitman arm length to duplicate the stock pitman arm. This would let me use the stock drag link, eliminate bending up the dr. side hub-mounted steering bracket, and keep the drag link horizontal. This should eliminate any bumpsteer. This may have an effect on the number of turns lock-to-lock with the Toyota box but hasn't had an adverse effect on it's function in the F100's.
As for the rag joint...I prefer it over the pricey Borgeson joints. The RWD GM pass cars from the 80's use a joint that is splined to fit the Toyo box and can be mated to your GM column. I've used the GM tilt/telescoping columns and find them troublesome to shorten. I plan on using my stock shortened column. Good luck with your Firebird unit.
I've used the Saginaw pump, cutting off the pump fitting from the Toyo high pressure hose, and adding an SAE fitting and reflaring. This will keep you from having to spring for a new high pressure hose. The full-sized Bronco's have a good P/S cooler loop...plenty of tubing so you can bend and mount it in the return circuit and mount it on the cross member.
Please feel free to contact me directly as I have coached a number of builders through the process. I'm by no means an expert, but I have done the R&D, am aware of the common mistakes and am more than willing to share info. Hope this helps you get started on your conversion.
Dave | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | thank you for the offer i have ordered the kit from a vender to install a 69-87 chev pickup steering box onto my truck. it seeems alot easier and keeps it from having import stuff on it. the yota box was just looking like to much trouble to put in.
