3 members (TUTS 59, Oswald, Gray_Ghost), 91 guests, and 6 robots.
Topics128,184
Posts1,057,271
Members48,467
Socket Breaker
Socket Breaker
1965 Chevrolet C10
Instrument panel, with gauges
Hi folks.
I had to take out my instrument panel, to get get behind it to fix some wiring.
I put it all back together and I guess I'm putting some of the dash bulbs in the wrong places.
Does anyone have a layout of where what goes?
Especially the high beam light, I found the light, it works when I hold it against the panel body and flip the beam switch, but not when I put it in the panel, so... either, wrong hole or some other shenanigans are going on.
I've taken this thing out several times, usually I just move 'em around until I find it, but I'm at a loss this time.
Maybe I was just tired when I got done. grin
Anyway, thought I'd ask.
-Woog
I’m thinking the wiring diagram is in the 1965 supplement. Do you have the supplement?
Socket Breaker
Socket Breaker
Yes, I have the 63 shop manual and the 65 supplement.
-Woog
If interested, I made a post "Dash Gauges Made to Gauge Again" over in Electrical Bay documenting the refurbishing of my 66 C10 dash gauges.
Socket Breaker
Socket Breaker
Thanks for the tip, I'll check it out.
Socket Breaker
Socket Breaker
The hole for the bright light indicator is inline, just below the 20 mph mark on the instrument panel, with gauges.
on the user side, it is a small dark rectangle.
The hole for the bulb is back there, there is another bulb hole nearby, so you may have to plug and play a bit.
-Woog
