Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (baldeagle, 3B, Gdads51, Peggy M, Stovebolt48), 48 guests, and 2 robots.
Topics128,004
Posts1,055,250
Members48,418
#1388882 12/18/2020 4:18 PM
Having difficulty finding a useable flywheel for my 53 6 volt truck. Summit Racing has a new one for 55 Chevy trucks with 168 teeth and a Power Master Start with 168 teeth. Anyone familiar with this ?
Thanks, Scott
scottss60 #1388884 12/18/2020 4:30 PM
6 Volt starters require a 139 tooth flywheel. a 168 tooth item WILL NOT work properly. There is a slight difference in the root diameter and the pitch of the 139 and 168 tooth flywheel ring gears, and they do not interchange with each other. Are you changing flywheels because of a bad clutch contact surface, or is there damage to the ring gear? Ring gears can be replaced without changing the entire flywheel.
scottss60 #1388885 12/18/2020 4:34 PM
Chev of the 40s shows a 139 tooth ring gear for $65 on their web site. John
1949 gmc 1-ton
