| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Having difficulty finding a useable flywheel for my 53 6 volt truck. Summit Racing has a new one for 55 Chevy trucks with 168 teeth and a Power Master Start with 168 teeth. Anyone familiar with this ? Thanks, Scott | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | 6 Volt starters require a 139 tooth flywheel. a 168 tooth item WILL NOT work properly. There is a slight difference in the root diameter and the pitch of the 139 and 168 tooth flywheel ring gears, and they do not interchange with each other. Are you changing flywheels because of a bad clutch contact surface, or is there damage to the ring gear? Ring gears can be replaced without changing the entire flywheel. Jerry
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Chev of the 40s shows a 139 tooth ring gear for $65 on their web site. John 1949 gmc 1-ton | | |
